20-06-2020, 05:39 PM
(This post was last modified: 20-06-2020, 05:40 PM by Mike Watterson.)
I have the loose holders.
Anyway mount hole centres in mm from my home made valve tester.
5 pin: 39
Mazda Octal, International Octal (both Bakelite): 39 and 40, not sure which is which.
12 pin: 46
P8, B5 (like B4 but centre pin) , B7, 6 pin (with 2 fat pins) : 48
10 pin (German?): 49
P4: 49 or 50
The base excluding peg pins of P8 is maybe 33 and cutout is perhaps 40mm. The holes I have for the two octal bases are about 33, and that is generous.
So it's likely then either the 1941 is a later added guess or you have a very rare early all octal unless the paxolin octal bases are the size of the old paxolin B7 and P4 with a 5th centre hole.
EDIT:
I think the Mazda Octal is larger circle of pins than IO, but the mount spacing is the same.
5 pin: 39
12 pin: 46
P4: 49 or 50
EDIT:
there's nothing else to tag the date that I can see, just the pencil script on the inside of the back stating a persons name and a date, clearly, Tuesday 23[sup]rd[/sup] Sept. 1941.
