Nothing to do with radios, but if like me you find vintage maps fascinating and like to compare an old map to a new map then you may be interested to browse around the maps on this web site.
It has old maps of the UK and in the top right of the screen there is a slider bar which you can use to fade to the modern map, or overlay it so you can see the changes.
Both links below will take you to Wickford nr. Basildon on the map but you can zoom out and drag the map all over the UK (except the far west of the UK for some reason) and then zoom in again to see where ever you want.
This is a link to a 6 inch to 1 mile map that is described as Victorian,
https://www.archiuk.com/cgi-bin/build_nls_historic_map.pl?search_location=Wickford,%20Essex&os_series=1&latitude=51.608945&longitude=0.511453&postcode=
and this is a link to a 1950's map
https://www.archiuk.com/cgi-bin/build_nls_historic_map.pl?search_location=Wickford,%20Essex&os_series=7&latitude=51.608945&longitude=0.511453&postcode=
have fun
Mike
p.s.
Just realised if you want to see a part of the UK not covered in the links I posted then do a fresh search for where you want.
have fun
Mike
p.s.
