29-04-2019, 04:15 PM
(This post was last modified: 29-04-2019, 04:23 PM by ppppenguin.)
This advertisement for the TRW TDC1007 ADC is from the June/July 1980 issue of Wireless World. Before then, if you wanted to convert analogue video to digital it was a very complex and hairy board full of components. To do 8 bit conversion at video speeds (12MHz and higher) wasn't easy back then. The classic dual slope and successive approximation ADCs just can't run that fast. The opposite extreme is a parallel converter, with 255 comparators, a resistor ladder and a load of logic. That's what TRW accomplished in this chip but it's just about impossible with discrete comparators.
The method the BBC and others used in early digital video work was to do a 4 bit coarse conversion with a parallel converter. Then convert back to analogue, subtract from the input to get an error signal. A 2nd parallel converter then measures the error signal to get the low order bits. It's tricky to design but it worked. I think Quantel made a converter that converted just 1 bit per stage. Lots of tricky delay matching. A sort of pipelined successive approximation converter.
This TRW chip was a godsend to designers, even at over £300 each it was bargain. That's something close to £1500 in today's money. It was also physically huge, about 3" long and over 1" wide, a chip for your nightmares.
I suspect it had its origins in radar or other military work but it won an Emmy award. It was THAT important.
Data sheet:
https://www.datasheet.live/index.php?tit...:PdfViewer&url=https%3A%2F%2Fpdf.datasheet.live%2Fdatasheets-1%2Ffairchild_semiconductor%2FTDC1007J1C.pdf
Now several 8 bit+ 30MHz+ converters are casually integrated into things such as PAL/NTSC decoder chips.
Data sheet:
