20-11-2018, 11:36 PM
Trevor has kindly sent me the CRM92A CRT that was in his Ekco TSC30. The original tube in the TS105 is broken and for many years I had been on the lookout for a replacement CRT. Now I have the tube for the set it's time to start rebuilding the set. Unfortunately many of parts belonging to the set are scattered about the shop so the search is on to find the missing bits.
Way back in 2006 I tried out a Mazda CRM93 in the set but good focussing was not possible.
A B12A CRT base socket is presently fitted so this will have to be replaced with a Mazda Octal socket for the correct CRM92. How the 12.6volts heater supply for the CRM93 was found in the circuit will have to be investigated. The CRM92A has a 2volt heater.
The TS1051105 has a switch tuned radio receiver. A modified version of this chassis was fitted in the pop-up CRT 15" model TSC113.
Geordie McBoyne.
Geordie McBoyne.
