22-10-2018, 09:25 AM
PCB leakage is quite possible as Lawrence has said. The very high valve grid resistor is to keep the grid current low. UCL83's are prone to leaks but normally in the pentode section and mind the grid voltage will be damped somewhat by your DVM so could even be more negative in real life.
Is the audio distorted at all?
