21-10-2018, 01:57 PM
Quick question about this record player, perhaps someone more learned about valve amps can shed some light on this curiosity.
The schematic is available in a trader sheet, just google the search term HMV2304 and it will pop straight up as a PDF.
Ok, so it all works, but there's a slight mains hum which I'm trying to eliminate. If you turn the volume pot to zero the noise goes. If you disconnect everything before the volume pot then the noise remains the same, so the noise is somehow introduced in the circuit around V3a (the pre-amp).
The curiosity is that when I measure the voltage on the Grid of V3a with respect to ground, I get a NEGATIVE voltage. Bare in mind that there is no negative (WRT to mains neutral/earth) voltage anywhere in this set. The voltage decreases (increases negatively?) from 0 to about -2v as the valve warms up, if you disconnect from the mains the voltage very slowly drops back to zero. My thoughts were that the AC heater chain (this is the most earthy valve in the chain) was somehow acting like a diode on the grid and causing a negative voltage on this pin, but if that were the case then the voltage would disappear the instant that power was removed.
Very odd indeed.
I've also checked the main rectifier valve and the mains filter cap (by substitution) and the noise is exactly the same.
Can anyone help?
Very odd indeed.
Can anyone help?
