21-09-2018, 05:08 PM
Attached is a circuit for a common cathode triode gain stage, which is pretty bog standard in most valve amplifiers, apart from the volume control that is. The problem is with the volume pot set at low/zero, , the grid resistor is "nulled" out by the bottom half of the pot set to around zero ohms,with the control grid sitting pretty much at ground, which AFAIK, is bad practice.
I've seen some guitar valve amps with this sort of setup, apart from the addition of a grid leak resistor or two, but better amp's and some pre-amps use one triode as a fixed low gain
"buffer" prior to the volume control.
How would one implement a volume control without the use of another triode "buffer"? Is there a configuration/circuit that allows the use of a pot before the gain stage but doesn't have the problem as above?
Cheers, TFL, Andy,
Cheers, TFL, Andy,
