Hi Rob, looks as if you MAY have a faulty output transformer, to earth, this would cause the resistor across the cap,s Smoothing, to overheat and eventually burn. A replacement loud speaker transformer will eliminate this, it was fine till you put the feed from the transformer onto the capacitor, also check the tone cap across the transformer i think its C19 THIS SHEET 0.01uf....regards....Alan.
