05-05-2018, 07:30 PM
The two BRC 2000 series colour TVs in my collection need repair and then the possibly of fitting a transductor to remove the pin cushion distortion inherent in these otherwise fine sets.
Any other modifications to improve performance and reliability will be considered.
The sets are a 19" Marconi 4701 and a 25" Ferguson 3700.
Starting with the Marconi.
The loudspeaker employed in this set is a 20 ohm 6 X 3 inch elliptical type.
Being unable to find a direct replacement I've fitted a pair of 9 ohm units removed from a scrap LCD TV.
In order that the new speakers will fit in the position of the original unit an adaptor plate will be required. This new part has now been made and fitted. Now all that is required to do is refit the chassis and find out if it works.
Geordie McBoyne.
Geordie McBoyne.
