20-04-2018, 08:06 AM
The 6/30L2 is pin compatible with the ECC85, they in the main work but are on the edge, I tried one many years ago with no success, then a few years later tried another in a different set and it worked OK. I found out then that some did some didn't and others only at the low end of the band.
Emma's Dynatron Marlow has an ECC88 fitted and its really sensitive, works so much better than it did with the ECC85/
