I am currently restoring this radio, https://www.radiomuseum.org/r/kolsterbr_402.html . I have had it for a number of years and the only thing I did with it was to take the chassis out and clean the dial and dial window to take photos. I cant remember now why I did not do any more work, but it may have been because there is no information that I could find on it, up until now.. I also seem to have an idea that I thought the speaker energising coil was open circuit, but it is OK, it measures 3k, the mains transformer and speaker transformer also measure OK.
I have just recently discovered it appears to be the same chassis as the STC 40 and the KB 444, https://www.radiomuseum.org/r/kolsterbr_444.html but in this radio the speaker wiring is hard wired into the chassis rather than via a 4 pin plug and socket on the side of the chassis.
The cabinet is in quite nice original condition, including original speaker cloth, for an 84 year old girl, but there are a few old worm holes on one side. The chassis also looked fairly original, but now on closer inspection there have been some component changes. I thought it was a bit of a mess under the chassis until I saw the photos of Sam's Seymour radio,
One change in particular which is rather odd is the cathode resistor R5 250 ohms, it has had a 140 ohm resistor added in series, even though the grid coupling cap C3 has been changed for a metal Sprague type. The Sprague cap is showing a little leakage so I have replaced it with a nice new one, I also removed the 140 ohm resistor and connected up the 250 ohm one. It actually measures 260 ohms, but that is near enough for me. The resistors that KB used originally during the early 30's are very good at retaining their value.
I am continuing to change the caps and check resistors, in this radio Kb had a rather strange habit of using wax paper caps for values as low as 100pF.
Mike
Mike
