19-01-2018, 11:55 AM
I got this curious device sometime ago off a fellow forum member. It is a Level Measuring Set #30A and Oscillator #132A. There was conjecture at the time that it was BBC , but it looks military being painted Navy grey, though why would the Navy etc be wanting an AF osc and recording meter? It is also in a 19" rack size chassis. I can't find anything at all about it despite numerous attempts.
I've finally got it working after a few attempts feeding it 22v DC, anything less results in clipped sine OP. The osc goes from 20hz - 20khz and the dial is bang on according to my frequency counter and goes from about 100mV - 6v P-P. The OP does have stability problems though, turning the freq dial sometimes kills the oscillation and it has trouble reviving. The OP also seems a tad touchy to various loads, my distortion meter attenuates the OP by about 90%, my AC meter by 20% ish. Also the frequency response isn't flat being attenuated at low frequencies and at the extreme HF end.
I got a THD reading of 0.03% yesterday, but got readings of 10% today @ 2khz. It could be that I have it powered incorrectly, it may need split rails, +15v 0v -15v say. Unusually chassis/ground is positive.One odd feature is the meter, it reads +/- 1dB, not the actual level of the OP.
The rec level meter records the OP in dB, but the attenuator doesn't match that of the osc. IE it stops deflection as the osc level decreases.
Both are very well constructed, from the dates on caps circa 1976 and both use germanium Q's and diodes. The frames are made of that big lads Meccano, sorry not sure of correct name. Both also use Sifam meters, gold plated connectors and decent pots as well as having custom made tfmrs/coils/inductors - I presume.
I can't indentify two components - RY1 & 2, RY1 looks like a point contact diode, RY2 a light bulb. Could it be a Wein bridge osc as the OP is boingy?
Any ideas or info would be welcome. I doubt I'll keep it as I have several better sig gens, drop us a PM if you have any similar gear, I may consider passing it on.
Andy.
PS, I'll be posting a video on Youtube at some point that looks at it in more detail.
Andy.
