29-11-2017, 12:18 AM
    	Although repairs have been carried out the burn pattern can still clearly be seen on the wood however very little if any to vegetation close by.
The heat clearly came from the drop wire running to ground level as the wood is only burned on one side and only to the top of the drop wire.
The drop wire is on the south side of the pole.
