25-08-2017, 01:05 PM
(30-09-2016, 08:36 PM)Mike Watterson Wrote: At RF it's common for grounded grid to fed f- and f+ via a 1:1 transformer as a common mode choke. The DC cancels (f- to 0V and f+ to battery) ...
That's not strictly true! Although it's probably OK in practice, unless you use a really small toroidal transformer which saturates easily.
The current entering one filament lead isn't balanced by the current leaving the other. Some electrons take off from the filament (which is the whole point of heating it!) so there is a net DC current in the common-mode choke.
Regarding other matters, I made a push-pull driver using two 1j24b's, one operating as an anode follower, I am really pleased with it! HT is fifteen CR2032 lithium cells (from Poundland). Next task is a push-pull output - I already have the 1p24b's which look rugged devices. But I'll neede a better power source.
