16-03-2017, 02:58 PM
One point to consider is we don't hear as often about the failings of work undertaken in an industrial setting. Living in a boat yard I see a lot of things that go wrong. To give an example, someone had a marinized but non-running VW GDR diesel in his boat. The mechanic concluded the problem was no fuel lift pump had been fitted so fuel couldn't rise above tank level. The customer started to pay for work to be done. However from a Hayne's manual I discovered the Bosch injection pump on this German engine needed 12 volts on it. It would then lift fuel as well as inject to the cylinders. Few marine engines have pumps like Bosch and most use crankcaase pressure to power a mechanical fuel pump. That's partly why I became to this day a bit zealous over schematics.
Also those here in the trade, consider doing marine electrics as they can't find people. There"s a huge shortage.
