09-12-2016, 05:41 PM
A HANDY HEADPHONE MATCHING UNIT
This headphone matching unit was devised and built today. It is for matching normal low-impedance headphones with a stereo jack plug to, small valve receivers, in order to remove the need for a matching transformer in each project.
Basically, it is an LT44 audio transformer with the high impedance leads going to a mono 3.5mm jack plug. The low impedance leads (one half of the centre-tapped section) goes to a 3.5mm stereo jack socket wired for mono.
I had to rack my brains for a suitable container, but when my glue stick dried up, it occurred to me that it was perfect for the job. I sawed off the end, and pulled the insides out, and washed it thoroughly. I fitted a wooden plug in the open bottom end, and filled in the gaps with P38 car paste. The whole thing was then rubbed down with wet & dry paper to obtain a suitable surface for painting. I drilled a hole in each end, one for the input lead, and the other for the output jack socket. I sprayed it with aerosol grey matt primer car spray from Halford's. After wiring it up, I packed each end with a bit of bubble wrap for insulation, and snapped the top (containing the 3.5mm output socket), back on.
In the image, it appears to have a pinkish colour, but that is because I photographed it in artificial light. It is a light, matt grey in the light of day. It has quite a professional look to it, is light and handy. No-one would imagine it was a glue stick. Works a treat.
Bob
Bob
Once again, I must bow to your superior knowledge. But all I can say is that I have been using LT44s for years as output transformers for "small valve receivers," and never had the slightest problem with them. None have ever burned out, and the quality of sound reproduction appears to me to be as good as it can get. But after years of listening to morse, I probably can't tell the difference anyway, although I still have very acute hearing!
and I only use the cheapest headphones that money can buy!
