02-12-2016, 11:43 PM
If Alan has had this VC1 for 30 years I find it hard to believe that its a LT1650 chip based boost converter.
There is no way of switching it off, the dry cell would discharge much too quickly. I can't see how setting the meter to off on both switches would isolate the battery from the VC1.
Alan rarely has changed the cell he says.
Its alien technology if it just sits there until you need to work on the high ohms range without consuming any power at all. Certainly alien to me which is why I asked.
I have worked with Avos since a lad and I have never seen one.
It probable dates from around when the model 8 MkV came out, Avo seemed to be fond of flex copper connectors then, they always had trouble with them too.
I think we need more information on this device, need to produce a working copy.
Boater Sam.
) feeding back to the base of the transistor. It's incredibly efficient. And simple.
