01-12-2016, 07:10 PM
This is a rapid solution to the long running problem of 15 volt batteries for AVOs.
Once you get good it becomes a 10 minute job
I have discovered that a 15mm water pipe stop end it the correct length to make up 5 CR2032s to the length of the original BLR121.
It was a very rapid job with a bit of insulation tape and even the label off of an old one.
I did fiddle about with slices of pipe before coming up with the idea of the stop end without the nut or olive.
As the cells are sold as calculator batteries this had to be a calculated solution.
