29-09-2016, 01:58 AM
The specimen in my photos was pulled from an old deck in the late 1980s.
It is fitted to a heat pump and thermal battery and drives a small gear pump.
The motor has done an estimated 200,000 hours and out lasted its first heat pump my a matter of weeks.
In the second photo a little bit of the heat exchanger can be seen top right and hardened oil and grease clinging to the pump housing to the left of the motor itself.
The bronze bushes are not a problem as the pump is immersed and the motor not so there has to be a washer allowing the rotor to "float" on the washer and not so much the bushes giving almost no sideways force on the shaft as it would be if it were on a deck.
The motor is mounted in an inverted position in this use.
I am pretty sure I have another coil to fix it with.
Has anyone ever found one of these motors that has been working this long.
