27-06-2016, 01:23 PM
A Grundig 2012 I am working on intermittently changes volume. This only happens on VHF, with M L and SW unaffected, and the volume changes are always to the same level. The slightest touch with a probe or screwdriver virtually anywhere in the circuit restores normal volume which may last for a few minutes before failing again. I have carried out all the usual checks ie switches, dry joints etc. The only suspect left is the EC92 in the VHF box. As I don’t have a spare to hand, are there any further tests I can make to confirm this. I can post a circuit if required.
Thanks
Mark
Thanks
Mark
