13-02-2016, 06:13 PM
(13-02-2016, 04:31 PM)Radio Fixer Wrote: Thanks for that link.
I don't understand how it is a magnetic aerial although he uses the term. To me it has to be an aerial shielded from the E part of the received signal. So shouldn't it be a wire inside a tubes as per the Wellbrook? Wonder how they get the ferrite inside the tube and what difference that makes.
In the Den I have a large window and I could put a tube all the way around it with an inner wire, coupled to the amplifier. Any ideas if that would work? I understand that shape is not critical, it doesn't have to be round and larger presumably means more signal? With the Wellbrook, for the lounge best radio, it is on a rotator bought NOS for a very low price but for MW and LW I don't find it any advantage so having a window aerial fixed in a single plain wouldn't matter. Actually the Wellbrook started off on the window sill of the Den and worked very well for the radios in there, with large signals. This was also the case when tried with the HMV 650 just loose in the lounge. LW R4 closed the eye tube with considerable overlap but now garden mounted and 60 feet away signal is down and eye not fully closed. That just must be the loss in the RG59 coax.
thanks for ideas Gary
Hi Gary.
I'm sure you will find all the info you need on how magnetic aerials work on the internet.
It would take up a lot of keyboard time for me to explain it.
Have a look here: http://sidstation.loudet.org/antenna-theory-en.xhtml
My main gripe with the wellbrook was its signal output, a higher gain amp would have been useful, later models did have a bit more but even then it wasn't great.
When I "repaired" mine a few years ago with the circuit depicted in the thread signal levels increased although the loop didn't work up to Band 1 after.
I actually received some excellent Band one TV DX early on but there is little point now as we are bombarded with "Digital is best" and there is virtually no analogue TV DX to be received now.
The latest incarnation though does perform better and is working well up to the 10m band.
Long coax cable runs shouldn't give any noticeable losses on MW and short waves, most likely the problem is impedance matching, a 50 ohm cable is hardly likely to match an old valve radio aerial connections that are high impedance.
Try making a little matching transformer with a ferrite ring at the radio's A & E sockets, I've found this helps no end.
Good luck
