11-02-2016, 12:08 PM
(11-02-2016, 09:03 AM)Radio Fixer Wrote: The built in Sat Nav beats the stick on the window ones, it has so many good features and clearer instructions but again is expensive as are the software upgrades.
I hate stick on the windscreen ones - it is always such a stretch and pain getting the damned thing on or off and, if it is as low down the windscreen as I'd like, impossible to reach if I want to change anything.
In practice, it ends up far enough up the screen so as to obstruct my forward vision, which I don't like.
I have a Tom Tom with free map upgrades for life which I used in my previous Focus (02 Reg) which had a little receptacle to the left of the instrument cluster, I made up a bracket and a simple latching mechanism. The base of the bracket was a flat plate that fitted the opening and the latch dropped down behind the front edge - I could fit it and remove it in a couple of seconds. The Sat Nav was in just the right place to look down and take everything in at a quick glance.
I now have another Focus (61 Reg) which doesn't have any cavities, nooks or crannies to fasten anything to! Having the thing on the windscreen is driving me mad and I don't want to leave any permanent mark on the fascia from a permanent fixing - nor do I want to obscure any controls, switches or indicators, of which there are many!
I think I might have eventually found a solution.
There is an information display for the Radio, Phone, etc. in the centre of the dash which has a rigid plastic surrounding recessed into it.
The plate the previous bracket was based on is about 1.6mm thick and is a force fit between the top of the rigid surround and the underside of the padded dash - indicated by the red line below.
I plan to add a small lip as a depth stop so that it lines up with the edge of the dash and a right angled bracket over to the left on which the Sat Nav will clip, using a pair of joining brackets, for quick installation and removal. I've guestimated that, when swivelled towards me, I will still be able to see all of the information panel behind it ...
Unlike a built-in device, of course, I can still use it in any hire car I need to drive, including during a possible sunshine in Spain later in the Spring ...
