14-10-2015, 08:23 AM
My neighbour has run a 3 core, 4mm steel wire armoured cable down to his shed, about 80 feet from their split way consumer unit ( two elcb, I'm not familiar with the modern term). There is a 32 amp spare circuit breaker in the consumer unit which he intends to use. The cable will feed a ring socket outlet circuit and a couple of lights. He has a small metal consumer unit with two circuit breakers in already mounted in the shed, one for lighting the other for the sockets. The question is should he install an earth electrode, as I seem to remember that without an electrode he is exporting the earth protection and some special precautions should be taken. Any advice will be much appreciated.Ted
