15-07-2015, 10:32 AM
Continuing my accrual of test gear applicable to components used in receivers up to 1935 it occurs to me that some means of plotting the characteristic curves of simple valves would be useful, particularly for homebrew designs. I know manufacturers were in the habit of providing this information and that it’s an easy matter to get hold of, but my understanding is that valves do suffer degradation, particularly the older they are, the more use they have had and the conditions under which they have been stored. So being able to plot the curves for the valves I possess might be an advantage. At the very least I need some way of telling how well they are working.
All the receiver circuits I have considered use triodes, with just the odd one or two having pentodes too. With this in mind I was going to start by constructing a very simple triode valve static curve plotter along the lines of the attached circuit. Of course it would be nicer to have a tester that would accommodate pentodes too but I fear to build one would be a lot more complex and taking me towards the realms of a proper valve tester. At present I have neither the skills to build one nor the funds to purchase one. And the fact is I don't want to buy one. I'd much rather make something as it contributes to the learning curve.
The circuit I have designed uses batteries for HT, LT and GB. The LT supply is fixed and uses 2v Cyclon SLA cells to supply 2v, 4v or 6v as required. The HT and GB supplies are variable by means of potentiometers with accompanying voltmeters to select the desired voltage. A milliameter in the anode circuit supplies the data for plotting, which will be done on an Excel spreadsheet with a graphical output (as illustrated in the attached picture).
I could begin building this circuit immediately as I have all the parts, but I recognise it has a number of shortcomings and I am consequently very open to critique of my proposed approach and to thoughts and suggestions for a better solution, keeping in mind of course my limited knowledge and aptitude
Nick.
Nick.
