03-07-2015, 10:03 AM
(03-07-2015, 09:44 AM)pwdrive Wrote: If someone is going to do radio servicing/restoration and/or homebrew radio builds I would say a variable frequency RF sig gen is more of a priority than a variable frequency AF sig gen in the test gear stakes, that and a couple of multimeters, a decent analogue one and a reasonable or cheapo digital one.
The point about the analogue multimeter is important - most service manuals (all of the antique genre) had voltage readings taken with a 20,000 ohms/volt meter (or similar), e.g. an AVO, which would potentially give very different readings when measured with a typical DMM at 1,000,000 ohms/volt input, i.e. the DMM will read higher as it's presenting far less load to the the device under test (DUT).
The second point about analogue meters is that they "average" readings due to the mechanical and thermal inertia of their workings - digital meters take a snapshot ever few milliseconds or so and display that, which means that on some signals they can appear erratic.
Know your test instruments
Don't blindly trust what they say they're doing - they may be being "economic with the actualité" as well as adversely effecting the DUT's behaviour...
