13-08-2014, 03:04 PM
(This post was last modified: 13-08-2014, 03:05 PM by Radio Fixer.)
Well Al, I've been using soldering irons for 60 years so not worried about having an accident with a 200W iron.
The bit on the Weller has never needed filing (plated with something) and at only 1cm wide I have had no problems getting it in place on the chassis I work on.
Its the familiar story if you need it you buy the expensive tool. If not you go down market a bit and even look around second hand for Weller stuff, say at swap meets.
cheers Gary
cheers Gary
