14-03-2014, 11:04 PM
so as i don't make a mistake and understand exactly what you both are trying to tell me. i tried 12v first with a 5 watt 220 ohm resistor which i had. digi meter set on 20 volts no load it read 11.83v when connected it dropped to 11.67v then continued to drop to 11.60v over a twenty second period. would this be charging of the caps. i switched off until you say it's ok. What i did notice the speakers are kicking in when first switching on. i tried a few times to make sure. thank you richie
