14-11-2013, 05:28 PM
I thought that might be the case.
I'm sure in some part of the manual there is a bit that says that the ACM terminal is the "common signal ground" and in another part of the manual as "common terminal of analog and control signals" although I can't seem to find the former reference when I last looked but that would be no suprise with my eyesight. The only reason I mention this is that using the terms ground and earth within the same manual could confuse some folks. Maybe I didn't read it and was just dreaming....
