26-08-2013, 10:00 PM
Folks,
I was going to update the firmware in my Panasonic Lumix digitial camera today. Normally, I would simply accept the firmware update from the manufacturer as gospel and not query it. For some reason, I carefully checked thorugh the small print and found that the only reason for this update was.....
To "prevent the unauthorised use of non-Panasonic batteries".
I already have two spare batteries purchased from ABC products for £7.99 each.
Genuine Panasonic batteries are thieving £19.99 + postage.
Panasonic are obviously overcharging for their batteries and realising that they are losing out, are trying to prevent the use of third party battereis 'for safety reasons'. What rubbish.
So DO NOT UPDATE your Lumix software as it makes the operation of your camera WORSE. Your second-sourced batteries will no longer work.
You have been warned !!
The same applies to HP Photosmart 5524 printers.... DO NOT update the printer firmware as you will no longer be able to use any third party supplied ink cartridges at £9.99 a set (which work better than the originals and contain more ink) but only the genuine HP versions at £29.99 a set will be recognised. Thieving B*stards.
Hope that helps.
Best wishes,
Dennis.
Hope that helps.
Best wishes,
Dennis.
