Mark:- Japanese transistor prefixes: my understanding is same as yours - which I know to be correct: 2SA, 2SB = germanium; 2SC, 2SD = silicon.
Mod Edit: This is not true - the scheme does not differentiate between germanium and silicon.
2SA: high-frequency p–n–p BJTs
2SB: audio-frequency p–n–p BJTs
2SC: high-frequency n–p–n BJTs
2SD: audio-frequency n–p–n BJTs
From https://en.wikipedia.org/wiki/Transistor..._.28JIS.29
The link in post #7 originally pointed to that data, but the link no longer takes the reader straight to the scheme because the page has changed since then.
Anyway, to your Panasonic radio problem: I've read what you have written. If I understand that correctly, with it you can receive BBC R2, albeit a bit weak, but cannot receive other stations on VHF FM from your (roof + amp.?) aerial. Yes, obviously you could have a low gain 'front end' transistor or a biassing problem with it. But have you considered RF misalignment of the RF stage - misalignment either on account of someone twiddling or a component fault that has upset that alignment? You'll know what to do to check that out and you have the necessary kit to do it, (I don't believe in teaching my granny how to suck eggs
), so . . . .
OTOH, perhaps I've misunderstood / misread something (not unusual, plus it is now late at night - I really should be
Al.
), so . . . .OTOH, perhaps I've misunderstood / misread something (not unusual, plus it is now late at night - I really should be
)Al.
- so well done.
