14-11-2012, 08:38 AM
The resistor between OUT and ADJ is not critical. The datasheet recommends 240 ohms because it gives a convenient current of ~5mA that makes the numbers easier; all the LM317 does is maintain a fixed 1.25V between OUT and ADJ, while endeavouring to draw as little current as possible via the ADJ pin so that the output can be determined by resistor values alone. If you choose 1.2k, the current is ~1mA, and that's about as low as one should go if the ADJ current is to remain insignificant compared to the current in the two resistors.
In other words, deviating from the "default" 240 ohms so that the potentiometer you happen to have covers the range the require is absolutely fine, providing the operating current is more than ~1mA.
Or, worry ye not
Joe, if you add a capacitor from ADJ to ground, then the diode from ADJ to OUT becomes mandatory. I tend to use them as a matter of course.
Or, worry ye not
