13-08-2012, 02:00 PM
More years ago than I care to think I found an old gouge in the shed. The handle was split and the business end utterly smashed. My Mother said she was pleased that it had turned up as it was a thing for getting nails out.
Until recent days I hadn't got the means to put it right but now have.
I re-ground it yesterday and made a new handle this morning. The latter is mahogany which probably isn't the best stuff to use but is all I've got. When and if something more suitable turns up at least I'll have had experience at doing it.
Unfortunately I didn't drill a wide enough hole for the tang so on initial fitting it split. Luckily it glued back together fine and this is all part of the learning process. It's certainly ended up very nice.
- Joe
Until recent days I hadn't got the means to put it right but now have.I re-ground it yesterday and made a new handle this morning. The latter is mahogany which probably isn't the best stuff to use but is all I've got. When and if something more suitable turns up at least I'll have had experience at doing it.
- Joe
