01-08-2012, 04:41 PM
(01-08-2012, 02:15 PM)Geaney Wrote: Result:
Dropper Cap - 10.68uF
Surge Limit Resistor - 33 Ohms / 3 Watt
I've found a source of motor run caps and a 10uF one is the largest value that just fits into the large (electrolytic) can.
I'll order up the cap but let me know if I've missed something crucial here.
Cheers, John
Great to see the rapid progress John. If you wished to you could of course add a 0.68uF cap in parallel with the 10uF to get the exact value, but I'd have thought that for all practical purposes, 10uF alone would do fine. After all, the caps aren't close tolerance anyway. As you've concluded, there just isn't enough space for an adequate-sized heat sink for resistive droppers.
Best of luck with the rest of the restoration John.
