30-07-2012, 07:28 PM
(This post was last modified: 30-07-2012, 08:06 PM by Robert Darwent.)
Hi David, John and Maitiu
Yes the paint is in grooves David, the following image shows it a little clearer;
I must agree, in my opinion they are great looking little sets;
As the comparsion image shows, they are perhaps two-thirds the size of a DAC90A;
No it isn't, but its quite a decent attempt by someone. I shall make a more authentic repro in due course for the set;
The electrolytics in my set are replacements but are 100 uF, 400 VW so that ties in with the circuit diagram. I've also found a couple of restorations of the set on the internet and both of those use 100 uF capacitors as well. So its probably a safe bet they are the correct value.
I've checked the two in mine and I've got a 6.0V, 0.1A and a 6.5V, 0.1A fitted! Both replacements of course.
Please bear with me as my flatbed scanner is not behaving itself at the moment. I'll attach a scan as soon as possible after I've sorted the problem.
Again bear with me and I'll have a look at my chassis for you John.
Regards
(30-07-2012, 12:02 PM)Yorkie Wrote: Did these sets have painted grooves around the cabinet, or is that my eyes deceiving me?
(30-07-2012, 12:02 PM)Yorkie Wrote: Quite a striking looking set. Makes a nice change from the ubiquitous DAC90A!
(30-07-2012, 12:02 PM)Yorkie Wrote: Is that the original back panel on yours Robert?
(30-07-2012, 02:20 PM)Geaney Wrote: Some of the comments so far have suggested that 100uF is very high for this type of circuit. Are yours definitley 100uF? if yes I'll change mine since I've now got some.
(30-07-2012, 02:20 PM)Geaney Wrote: Correction re my dial bulbs - they're both marked 6.5v 100mA.
(30-07-2012, 02:20 PM)Geaney Wrote: When you get your chassis out of the case I'd be very keen to see a photo of the underneath!
(30-07-2012, 02:20 PM)Geaney Wrote: Your dial looks in great shape so I may prevail on you to take a photo of it against a black background so I can see about re-creating one for my set.
(30-07-2012, 04:22 PM)Geaney Wrote: Hopefully I can find where it was connected and it's on a selector switch, not directly on a coil!
Regards
