07-04-2012, 07:18 PM
Hi Al, are your caps as close as possible to the 317's leads, if not you may have a power oscillator. These devices burst into oscillation at the drop of a hat. If you have more than about 1uF on the output, wire a diode backwards across the chip. If not the cap tries to discharge into the chip and it dies PDQ. 3 diodes and a fuse across the output is a good crowbar. I used similar circuits in an article for WW many years ago and it worked fine.
Is this the low dropout 317 you are using? If not it may need a higher input voltage to regulate properly.
Switch on surge on the valves should not be a problem as the 317 has internal current limiting.
These are nice devices but are full of traps for the unwary user.
Ed
Ed
I know that one of them I have used before. But . . . . )
