01-04-2012, 12:51 PM
Update, April 1st, 2012.
After a lot of research within and without the 'Net, I have now answered my own question: "Is this a Pye model MP?". And the answer is no, it isn't: it's a Pye model RS4.
The appearance is very similar (as discussed above), but the real 'give-away' that it was not a model MP was the fact that the MP has 3 wavebands (traditional LW, MW and SW coverage); mine has 4, including two SW bands: 15m. - 50 m. (called 'short') and 60m. to 200m. (called 'med. short').
At present, my camera is not available, but I did find some pictures of the model RS4 on the 'Net: these are below. The condition of mine is broadly comparable to what is seen in these photos - and I also now know for sure that the fitted ECH35 is a 'repair-by-modification': the correct valve is an ECH3.
[attachment=4434][attachment=4435][attachment=4436][attachment=4437]
The style of the cabinet and indeed the chassis is so similar to the MP40 that it does seem very likely that the RS4 was simply the forerunner of the MP model.
Al.
Al.
Apparently, the model RS4 uses a different valve line-up compared to what I have in this set, and that is what I would expect to find in the model MP. But the MP has 3 wavebands & speaker at the top of the cabinet. Mine has 4 wavebands and speaker at the bottom. So I wonder: could it just be that on account of the fact that the RS4 was in production during WW2 - as was the model MP - that because of shortages of parts, Pye built this set as an RS4 but used valves from the model MP?
). And it worked fairly well, too. The audio was not distorted, there was plenty of it on fairly strong MW and LW stations. However there is a slight tendency for a little 'tunable' instability: I suspect defective decoupling components, although the EF9 metallised screening looks a bit dodgy. Fortunately, the cct. looks quite basic, so I'm sure that a more in-depth investigation will reveal all. At least there weren't catastrophic component failures found ( I like tempting fate!
