26-02-2012, 12:31 PM
This now seems to be working very well apart from the magic eye.
Before shelling out for a new EM80 I thought it wise to check that the valve itself was at fault. I don't have a spare but have got an EM81 so I stuck that in. This was only marginally brighter and the EM80 was quite usable in the Pye whence came the EM81.
Changing a few resistors improved things slightly but neither valve is as bright as they should be. The relevant bit of circuit is here so any tips would be appreciated.
The set also still has two Hunt's capacitors in. These are a 0.0001μF and a 0.0005μF. I don't have anything that small in stock and about the only things I can find on sale are ceramic discs. Would these be OK? I'm currently minded to leave them alone.
Cheers
Joe
Cheers
Joe
