03-01-2012, 10:41 PM
I think the one on my AR-88 has broken. The Off/On bit works but it doesn't seem to want to switch to REC MOD or REC CW. It was working so I suspect one of the contacts or the *'wiper' is duff.
Does anyone have a spare or perhaps even easier some close-up photos of one so I can check the position of the 'wiper'?
Thanks -Andrew
* Wiper; I couldn't remember what the name of this part is called!
Thanks -Andrew
Checking around the mains lead connections certainly power was getting there but nothing out of the rectifier. Luckily I'd bought a new 5Y3GT to replace a U50 in a GEC domestic set so I whipped that out, stuck it in the AR88 and switched on. Within seconds the voltage stabiliser valve starting glowing violet and the speaker started to hiss. Result!
