28-12-2011, 11:02 AM
Rob - The drawing is only 'representative': it gives the general idea. Note the earthing connections.
Fuses: if the primary is wired to a fused 230-v. plug, I'd put a 3A fuse in that plug. As for the secondaries, not so easy to specify. Obviously, there is a upper limit of fuse current-rating so that the transformer secondaries are adequately protected. On the other hand, there is minimum size of fuse current-rating, which depends on the load: 1-amp would seem a sensible figure.
Al.
Al.
Perhaps I'd overdone it on the 'Glenfiddich' at that moment: that sorta thing happens to me this time of year :s
