10-12-2011, 05:08 PM
Hi,
A couple of years ago I made a 4” belt sander after watching an American video. The video actually showed a belt grinder in action and this is what I wanted to make. Once the machine was running I found that I had a lot of difficulty in obtaining the correct abrasive belts for metal grinding and at the time spent ages surfing the web for a supplier but without luck.
In the end I gave up and bought suitable sized sanding belts from eBay costing £10 for ten and these were 60 grit. Since making the sander it has been a most useful machine and is a pleasure to use.
http://www.youtube.com/watch?v=BYllaxuzMk0
I’ve recently been thinking about tool sharpening again and for many years I’ve tried both expensive machines and hand methods of trying to keep my assortment of tools sharp. I bought a 6” double ended grinder and restored it and this has been used to grind my tools but I hate the thing. It heats tool tips up rapidly and leaves a hollow grind which I find objectionable on my woodturning tools. I can’t fault the grinder as it is a top class Wolf and is very sweet running; I keep the stone dressed using a diamond dresser. I just can’t settle with it as a tool grinder.
Posting pictures on the forum of my home made belt sander re-kindled the belt grinder idea once again and this time I won’t give up until I have made the machine I dream of. The videos I saw showed belt grinders in action but didn’t give details as to the actual grinding belts; in America these grinders are common and a number of such machines for the home workshop are available here in the UK but are expensive and the belts are what I would consider short.
I was totally surprised to find an abrasive belt supplier on my doorstep within good walking distance; this is typical of my luck though when I initially wanted a supplier I couldn’t find one. I contacted this supplier and asked what they recommended as a suitable abrasive belt for grinding HSS (High speed steel). I received a prompt reply and have ordered 10 Silicon Carbide belts 50mm x 915mm (2”x 36”) and am now awaiting delivery. I believe the belts I bought from eBay are Silicon Oxide which are ideal for timber etc.
I now hopefully have the abrasive belts sorted out but have run into another major problem. I want the same size but in leather to use as a honing belt. I’ve spent days surfing the web and as far as the UK is concerned I find it a total waste of time. I’ve tried to obtain a ready made leather honing belt without success; I’ve surfed the web for shoe repairers; cobblers and tanneries. I’ve telephoned around and sent emails. I could have jumped up and down on the phone one day when I rang a shoe repairer in Heckmondwike to receive a reply saying “You have reached so and so and I hope it makes you very happy” then the line went dead; I tried this twice.
I couldn’t find a honing belt supplier so intended to have a go at making my own belt and couldn’t even do this because suddenly a bit of leather is no longer available. With steam coming out of my ears I tracked down a company in Frisco USA; at least it was on this planet and this company sells ready made leather honing belts or can make one to specification. I emailed my sizes and was quoted a rough price of $28 plus $15 shipping which I said was acceptable to me; since then communication has ended?
I contacted another firm selling abrasives here in the UK and this time enquired about honing compound explaining I wanted to hone HSS tools. At last something went my way and I was absolutely delighted when the company said they would be happy to send me some samples to try before buying. The samples arrived this morning and even without trying them out I’ve placed an order for two 1KG bars of compound; one each of Menzerna 523LBZ Grey and Menzerna Ulto 12 White. The sample bars would possibly last me for years but such companies deserve support and I’ll add all the details later.
My stubborn streak has fully kicked in and however long it takes me I’m now determined to make the belt grinder to my specification; I’m not surprised youngsters these days are happy to play with electronic games after all I’m a dinosaur who was taught 50 years ago to use my head and my hands to make things; in those days we had plenty of raw materials via scrap yards and there was a cobbler in every village. How times have changed.
To add to my misery the weather is dire and my keyboard is miss-keying driving me mad. This week so far we’ve suffered high wind and blizzard conditions. Today at last it reached a sweltering 5 degrees so I went into the garage this afternoon for an hour wondering if I would pass out due to heat fatigue. It wasn’t pouring down when I pulled the car out but when I put the car away it was soaking wet; I need something to moan about.
Whilst in the garage I pulled out a selection of electric motors and run them under power; I also pulled out a selection of metal offcuts and pulled out a pair of pillow block bearings with a ¾” bore. I’m out of stock of ¾” dia steel bar so will buy some as I’m too lazy to reduce some 1” bar. At the moment I don’t have a specific design for the new belt grinder but I can now give some thought to what I can make from all the offcuts I have in stock; it goes against my religion to spend money.
I’ve got a feeling making this belt grinder is going to test my patience and turn into another saga. I hope to keep posting details of work in progress and hope I‘m not boring anyone. I trust my chum Alan is reading this as it might save his friend parting with £350 to buy a factory made machine. More to follow (a lot) and I feel like taking a big hammer to this keyboard.
I could of course take the easy option and use the 4” sander already made but it would mean fitting a reversing switch as the grinding and honing belts run in the opposite direction also I want to incorporate better guides.
The picture shows what I have to work with and it looks very much like a nice belt grinder/honer to me.
Kind regards, Col.
Kit of parts for proposed belt grinder.
Kind regards, Col.
