23-08-2011, 08:17 AM
Hi Guys,
On my mystery PYE restoration (the one with no on/off switch) I bought a long shaft volume pot from Radio Daze (couldn't find an RS distributor over here). The Radio Daze pot comes as a kit where you manually add the on/off part. Alas the shaft was about half an inch too short and I had not ordered their shaft extension kit. So, I found some aluminium tubing that was a nice press fit for the shaft. I cut the shaft, got the baby gas torch out, heated the tubing, pressed on to the shaft allowing an extra half inch and it worked a treat. Looks a bit neater than having a bulky collar and grub screw affair as the way to extend the shaft.
Cheers, John.
Cheers, John.
