20-07-2024, 08:08 AM
It's what all these "back doors" in software are about. Getting access so you could do the very thing which someone has inadvertantly done. In effect very similar to the old "Basic" which in this case could be simplified to 10 Print blue screen; 20 GOTO 10. It maybe shows the limitation of the operating system (probably BIOS) in not being able to recognise a possible higher level error and providing a way out but I suppose that would just create further loopholes. I see the issue is that company('s) staff are locked out from being able to interact with the system so are themselves unable to act so IT staff are required for each machine. This is one that hackers all over the world will be viewing closely.
Although full details are not known it is perhaps lucky that military systems are not affected. I have seen it as a worry for some time that so many computers in the world are now connected by single pieces of software. With servers, at the lower end, many users seem to use older software which would give a variable effect (maybe) but Windows itself now demands automatic or prompt action which doesn't leave a lot of scope for user caution. At least with Linux machines you have a stop point in which you can abort any upgrade. I imagine UNIX is the same.
