15-11-2014, 09:02 PM
In the absence of Thinners, and little opportunity to get any, I decided I'd try Meths. I believe I've read somewhere that the Base is held on with Shellac and Woodflour so it was worth a try. I soaked it overnight and that loosened it OK. After that I sucked out the Pins, did some more soaking, and managed to prise it off with some more heating. Unfortunately I managed to break off one of the Wires up in the Pinch
I'll keep the rest for the minute. As a minimum I've got a proper Top Cap I can use.
The next step is to solder a length of my Cable to it. Helpfully the Pins are numbered inside the Base so even I'll be hard pressed to get it wrong
Alan
Alan
