18-10-2020, 07:08 AM
I've done simple 50Hz<>60Hz conversion by frame duplication or dropping. On some movement it can look truly horrible, most of the time it isn't too bad. You see this sort of conversion artefact all the time when watching video material on a computer. There may be more than one implied frame rate conversion before it reaches your screen.
Incidentally, almost any 625/50 monochrome monitor will lock to 525/60. The line rates are almost identical (15625 vs 15734) and most sets will cope with 60Hz. Some will give reduced height. This was used as a trick to replay NTSC VHS tapes in PAL countries. 3.58MHz NTSC was transcoded to 4.43MHz PAL while leaving H and V rates unchanged. Most colour TVs could cope.
. Well as least until after getting it, I fed it with a 625 line signal and seen a locked line but rolling frame. Then the penny dropped!
