13-11-2011, 10:27 AM
Hi,
A very good point David. Sorting the spindle job out could prove to be only the tip of the iceberg and my fingers are well and truly crossed that Alan doesn't find too many more problems. The metal rectifier was OK on the set I worked on as was the winding.
I once rewound a field winding belonging to a Murphy A30C using my wood turning lathe which at the time was fitted with variable speed control (3 phase). As you rightly say David these windings have a large amount of fine wire in them. At the first attempt the winding was almost completed when suddenly it collapsed. I was not at all happy after spending a few hours and being so near to success; the wire was wasted because it was badly tangled and these coils are huge.
On the second attempt I made a new bobbin with decent flanges and backed these up with pieces of plywood ensuring this time there was no chance of collapse. With the winding completed I wrapped it tightly with insulation tape then with cotton cloth before removing it from the lathe.
I think the spindle will be the hardest part of this restoration for you Alan as the other jobs if need doing will be more easy and straightforward.
Please bring the old spindle to Golborne Alan as I will be interested to see one of these again and I'm sure my chum David will also be interested.
Kind regards, Col.
Kind regards, Col.
