It looks suspiciously like David's has had the lamp-holder changed for a normal BC one.
If you've got dead lamps it's quite possible to smash the glass so you can remove the cap undamaged and then fit it to a new lamp. On the donor you cut the cap off to save the bulb itself. As the original was 200V a 240V lamp should run cool or t could be re-jigged to connect straight across the supply if not.
I now keep the caps off dead lamps so I can convert ES LED ones as they seem cheaper and more readily available then BC ones.
— Joe
— Joe
