24-04-2012, 12:44 PM
Thanks, Al. The circuit diagram is in post 29 above.
I'm still making use of the decent weather so will investigate later.
Cheers
Joe
Cheers
Joe
I thought that might have been a possibility: I was on the brink of suggesting that. So forget the above comment on electrolytics for now - change C9 first. If that doesn't fix it, change the following, testing after each replacement: C6, C4, C3, and C2. If none of those replacements fixes it, go back to my earlier comment about replacing the electrolytics.
The only silicon I see is the BC 108 at the front. O.K. perhaps I've missed a bit of this whole story. If some of the germaniums have been replaced with silicons, that explains a lot - since silicons will have a much higher current gain - especially at R.F. - than germaniums! I'd replace any of those substituted silicons with the correct germaniums
