09-12-2021, 06:29 PM
Jeffrey, did not get a notification so sorry for the delay.
Not always sure on terminology.
If I stick approx +25 volts DC into the Frame scan coils at 50mA I will get full deflection one way from centre of the tube if I stick -25 volts DC at (-)50mA I will get full deflection in the opposite direction from centre. So I would need 50 Volts peak to peak and the total current peak of 100mA. The resistance of the coil is 511 ohms so actually +/-25.55 Volts DC, the reactance at of the coils comes out at 373mH but at 12.5 Hz is low in comparison, some where around 30 Ohm.
This is where I do not fully know if things will work so I will add a paragraph or three here.
The line scan coils at DC needed 104mA at 6.5 Volts to fully deflect from centre to one side. If I take into account the reactance of the coils at 400 Hz, I calculated the line scan coils would need 14 Volts across the scan coils at a peak current of 204mA it is actually 25 Volts peak to peak with a bit of a spike which is overshoot from the flyback.
The line driver is an EL84 connected to the primary side of a home made 8.8:1 transformer, the HT is 265 Volts during the flyback period the voltage on the Anode pin of the EL84 is going up to 380 Volts and as the sawtooth is applied to the grid the current increases through the valve and the lowest voltage on the Anode is 150 Volts.
So that looks as though I have a peak to peak on the primary of 230 Volts and that matches with the 8.8:1 ratio of the valve, the idea was to keep the anode current change as low as possible so in theory I am changing some 23-24 mA in Anode current.
Back to the Frame scan add in a bit of reactance and I got that the X of the frame scan coil would still be in the region of 512 ohms?
So ignoring the inductance i would still be in the region of 50 volts pk-pk voltage from the secondary of the transformer. I picked 25 VA as a number for the transformer thinking that if I tried any mains transformer at that rating it would be OK as I assumed it was ampere turns that caused saturation and I would have 5 times what I needed at 5 VA with 12.5 Hz.
I can tell I am loosing the plot here and beginning to waffle and not getting to any particular point, so will stop and go cook tea. I may be able to return with a clearer head.
Adrian
Adrian
Learning as I go!
Youtube EF91 Valve
Youtube EF91 Valve
