06-07-2020, 02:06 PM
Mike Watterson Wrote:Amie Wrote:As a suggested method if you wanted to construct a sensitive infinite impedance detector for the radio using those valves, could you use a floating supply for the filament? A separate LT cell for each valve wouldn't be a hardship....but then why fix what isn't broken?I can't see how that does anything much as the filaments are the cathodes and the input impedance is much higher than regular valves.
My suggestion was more from the point of view of the linearity and ability to handle a wide variation of signal levels without distortion.
Amie
