30-09-2019, 12:26 PM
(30-09-2019, 10:05 AM)Amie Wrote: What I seem to be settled with is the ECL80, despite its shortcomings, a pig to bias, and it's liability to take off at the least excuse, it has a low heater consumption, is not OTT for my application, and, I kind of don't like to be beaten by a dumb valve!
Interesting you find it takes off at least excuse. I have found the same, using the pentode as an RF amplifier and the triode as a grid-leak detector, on medium waves (sometime I will finish this project).
(30-09-2019, 10:05 AM)Amie Wrote: As Kalee20 kindly sent me a small SE transformer to suit my needs I built another version with the ECL80, with no balance feature needed it could be compared with the mains transformer version.
Its rather good!
The frequency response is better, though not going down quite as far as the mains transformer version it appears.
Frequency response will be 3db down at 72Hz, that is due to your 2.2nF capacitor from triode anode to pentode grid, plus the 1MΩ grid resistor of the pentode. It will also be down 3db at 155Hz due to the output transformer's inductance (or lack of!). The two together do not give a good bass response.
On the other hand, the treble response could well be better with the proper output transformer. Mains transformers keep the primary and secondary windings well apart, for safety reasons. This really hurts the treble response. The output transformer does not need to have such separation, so the coupling from primary to secondary is better. Glad you like it
(30-09-2019, 10:05 AM)Amie Wrote: Also it produces approximately a third more power for three quarters of the current consumption....
That is probably because the component values you have used are not optimum values. If it works, fine! But for more current, you ought to get more power. (But you do need to have the right output transformer, in that case).
(30-09-2019, 10:05 AM)Amie Wrote: I will tidy this up for some glamour photos to post when I start putting all the elements of the project together.... Hopefully!
It will be the most complex thing I've built....
Can't wait for the photos, I'm drooling already
...A neater circuit ought to work better, anyway. But it has to be the right sort of neatness. People have been known to 'tidy up' a circuit, and find it does not work as well... sometimes instead of components tacked across from point to point with short leads, they lay them out in neat rows and the extra stray capacitances upset everything. So neaten-up with caution, and throughout the dressing-up, keep trying to make sure it still works.
(30-09-2019, 10:05 AM)Amie Wrote: So, I've learned a lot.
Congratulations! There's lots more to learn. My supply of 'things to learn' shows no sign of running out, and I've had a career in electronics
